Adhesives
solid surface join problem
3/30/13
Ricardo Rivero Member
Hi, I just stared working solid surface and I am having problems with joins. The material I am working with is the white by Samsung, and while using the same cartridge of adhesive it turns dark in some joins and seamless in others. I need a recommendation to save these sheets.
3/30/13       #2: solid surface join problem ...
Perhaps the manufacture has a tech line? Call your distributor and tell them that you are having a problem. They should be able to advise you. Especially if you got bad glue.
I am assuming you have received training or taken a certification class. If not you should do so before you fabricate any more tops.
3/31/13       #3: solid surface join problem ...
Bob
joints likely dirty, surfaces should be cleaned first with denatured alcohol (rubbing alcohol)
4/6/13       #4: solid surface join problem ...
cabinetmaker
Go online and find their fabricators manual.
I would also recommend a sheet of white melamine to work off of and keep it clean. If you use a sharpie to mark joints it has to be cleaned off and so does pencil, all of it bleeds.
If you cant find their manual try Wilsonart, Corian or Formica.
