Adhesives
coloring epoxy
9/4/13
DA
Can anyone offer some advice on what I could use to tint clear epoxy white.
Thanks in advance.
Dennis
9/4/13       #2: coloring epoxy ...
Robert Member
How about a white pigment like an artists oil color or a White UTC.
9/4/13       #3: coloring epoxy ...
rich
Buy white casting resin. Epoxy is usually amber colored and making bright white will be tough.
9/4/13       #4: coloring epoxy ...
Adam Spees
The polyester resin in gelcoat is green.
You will need to add alot of pigment to achieve a good white with epoxy.
Evercoat sells pigments for coloring resins.
Evercoat coloring agents
9/6/13       #5: coloring epoxy ...
DA
Thanks all for the advice, I will try these and see what works best for this application.
The epoxy that I am using now dries to almost water clear and I don't need to be solid white , just more whitish and opaque than what I have now, so this should be doable.
Dennis
9/6/13       #6: coloring epoxy ...
ThomasFR
I wouldn't advise any liquid coloring agent to epoxy, serious risk of ruining the chemical mixture & preventing proper curing. Would you pour watercolors in your varnish? Dry (inert) pigment powders are what we use.
9/8/13       #7: coloring epoxy ...
Bob
We use liquid Mixol tints all the time in epoxy, hasn't stopped it from curing yet. For small amounts of epoxy a couple drops will change the epoxy color and make it more opaque. I wouldn't suggest using a lot of color but a couple drops hasn't caused us any issues.
9/9/13       #8: coloring epoxy ...
farno Member
I just had this experience. Rich's approach is the one I used and it worked out fine. Try Smooth-On's Smooth Cast 300; mix some finely ground limestone into either of the two components before combining. Available at a good art supply store. Sets up fast.
10/1/13       #9: coloring epoxy ...
chris
Mixol usually but I have even used black spray paint in a pinch
