adhesive for wall sheathing on houseboat? -- 0 --
11/16
I'm building out a mini houseboat on a 26ft JC Craft Tritoon. stick frame construction/OSB T-111 siding, interior walls are 1/4" shop ply laminated with FRP Panels (I have "Green Choice" FRP adhesive made by Franklin/Titebond for the FRP skinning, but can exchange for another FRP adhesive if anyone has any opinions or experiences to share that might suggest doing so...)
My main question however, is regarding the 1/4" to sheathing assembly, and the T-111 OSB installation (which is already installed)
I have about 10lbs of weldwood "Brown" glue that needs to be used, and was considering using this to glue the 1/4" to the framing. but brown glue is the pinnacle of "rigid glue line" IMO, and I am not sure if allowing NO flex is sound in theory???
I could use yellow (aliphatic resin), I certainly have plenty of the FRP adhesive to trowel the studs prior to screwing the 1/4" on, and of course -no glue at all is a possibility!
the structure is simply a box that takes up most of the 26x8ft deck, 24" centers 2x4 walls + SYP 2x6 joists overhead, as top deck will be used. I know cabinets and stairs + conventional residential construction, and while I have built a couple boats, I am far from what I'd consider a boat builder, much less an aeronautical engineer. Power is a V6 Mercruiser, and calculations suggest 25+knots, so I would like to pickup as much structural integrity with as little weight addition as possible. -as for whether I should/shouldn't glue the interior or exterior sheathing + what adhesive/s to use -Any suggestions, advice or opinions would be greatly appreciated,
11/19 #2: adhesive for wall sheathing on hous ...
James, I think I would use some sort of flexible marine type adhesive which you can get in a caulking tube, like a polyurethane.
With that much power and speed, there will be lots of flexing of hull, which would destroy mechanical fasteners eventually.
You can certainly find what you need at West Marine or other boating supply, but I have been seeing some of those adhesive/caulks showing up in the hardware lumber yards at pretty reasonable prices lately from good brands like Locktite.
11/23 #3: adhesive for wall sheathing on hous ...
Website: http://www.handrailer.com
This is not rocket science and your weldwood brown is fine. If you're really worried over flex than go with Franklin type ll or lll. Personally I wouldn't allow or permit any flex between sandwiched layers of wall sheathing (why create squeaks). Liquid Nails and other flexible adhesives will positively let loose.
Hard setting resorcinol was the glue of choice for boat and plane builders since WW ll but now it seems to be epoxy. The Spruce Goose, British Mosquito Bomber, American PT boats, minesweepers and thousands of LLC boats (to name a few) all glued and screwed with resorcinol.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
