Adhesives
strongestway to glue 3mm pvc on melamine...
4/15/14
Bill Burscher  Member
Can't seem to find an answer to this question about PVC edge banding....I don't usually work with melamine.
I'm doing a set of cabs for a residential garage.... It will have melamine doors that will need to be edge banded. There is a shop that has a edge bander that can do the 3mm pvc for me and I can check to see if they'll do it. Someone said that I can abrade the back of the PVC and use waterborne contact to keep from having to drive doors around etc..
My question: Is the actual bond with the hot melt used in an edge bander stronger than the waterborne contact bond would be? I can prime and spray and apply strong pressure to the contact... People also mention melamine glue "roo glue" or even white glue ( not sure what that is, I assume it's not white wood glue) not trying to cut corners, I just want the best bond... Thanks for the help....
4/15/14       #2: strongestway to glue 3mm pvc on mel ...
You probably shouldn't abrade the back as it has a primer on it.
3mm PVC has quite a bit of springiness to it. Best put on with a heavier bander using a high quality adhesive. Hotmelt adhesive goes down hill the longer it is kept hot. Banders with small glue pots and auto fill can keep the glue from over cooking. So much about edgebanders is operator dependent that it is hard to say if the place you are considering is good or not.
I think contact is a poor 2nd choice.
5/7/14       #3: strongestway to glue 3mm pvc on mel ...
Bruce H
Nothing sticks 3mm as well as adhesive applied with an automatic edgebander.
