Adhesives
Cleaning out glueing equipment
9/18/14
dustmaker1 Member
What solvent would be best to clean out hardened pva glue from equipment, I believe it to be regular Titebond? Never had to to this but we inherited some equipment with solidified pva and would like to use it if possible.
Paul R
9/18/14       #2: Cleaning out glueing equipment ...
Soaking it in Lacquer thinner will soften it eventually. Make sure there are no seals that might deteriorate.
9/18/14       #3: Cleaning out glueing equipment ...
Mark Elliott Member
If it's Titebond Original then water will soften it over time. Warm water will speed the process up.
Mark
9/18/14       #4: Cleaning out glueing equipment ...
dustmaker1
yes, I am soaking in water now but some is r deep and really cured up. Just thought there may be another solvent to speed the process.
Paul R
9/22/14       #5: Cleaning out glueing equipment ...
John Costin
My son the chem major says "pretty much everything can be dissolved in acetone". I have used it successfully on Titebond.
John Costin
Veneer Services Unlimited
vsu@gwi.,net
207-985-7221
Custom Veneered Products for the Woodworking Industry
