Edgebander glue pellet life span
11/6/14
I have a small edgebander that is pretty lightly used, I've used maybe 1/8 of the bag over 3 years, it's kept in a big bucket with a lid to keep dust out, but not air tight. Wondering if I should keep using it or if it should be replaced before 2025 when it runs out lol. Seems to be working fine, just scared of receiving a wave of callbacks one day because I waited to long to replace it...
11/12/14 #2: Edgebander glue pellet life span ...
Hi Mike,
I wouldn't be too concerned as there is no chemical change on use only a form change.
If it went off that quick all our edges would fall off.
Cheers Marty
12/12/14 #3: Edgebander glue pellet life span ...
Our edgebander uses a cartridge (Dorus HKP25) instead of a pellet. We rarely use the black but I have a case of it, stored on the concrete in the original cardboard box/clear plastic bag. There are maybe 9 cartridges left and the shipping date was 1999. Still works fine; we just ran a job in the black so I checked it by edgebanding a piece of scrap and trying to remove it after cooling. It still holds great.
12/31/14 #4: Edgebander glue pellet life span ...
Be careful of reheating your glue time and time again. We have been having issues with glue not sticking to the edgebander and I believe it is because we heat it up to run a small batches. I think it is messing the glue up. Has anyone else had issues like this?
