Adhesives
glue
3/23/15
Todd Stuart Member
Website: http://www.jpkassociates.net
We are preparing to make the switch to using a case clamp. We unfortunately are still using blind dado system. We are looking for a glue that has a fast set time like 10 minutes. Any suggestions ?
3/24/15       #2: glue ...
You would be a lot happier going to dowels when using a case clamp. 10 minutes is a long cycle time for doweling. I've timed our cycle time and thought it slow @ 3 to 4 minutes. In-feed man puts hardware on, injects glue in face holes, knocks case together and pushes into clamp. Out-feed man inspects, puts drawer/door & shelf, moves to shipping. Dowels seize very quickly, glue isn't "set" but holds well enough to handle.
For a fast glue use hot PU, expensive but fast. Franklin & 3M sell the setup.
Are you using some additional form of attachment?
3/24/15       #3: glue ...
Todd Stuart Member
Thanks Larry , yes we are going to make the switch to dowels ASAP.But that could be awhile. Thanks for the info.
