Adhesives
Clamp time for vac pressing….
4/23/15
JeffD
I'm curious how long you guys leave your parts "clamped" in the vac bag? I know there are a million variables, but generally speaking using Titebond and Titebond Cold Press on solid wood to wood, or veneer to mdf, with no opposing force, (bending parts for instance), I usually go about 3 hours. I'll then stack parts and let them sit overnight before milling.
As I was waiting to get a second set of parts in today it started me wondering if I could pull them after 2 hours? I'd get at least another full set of parts in a day which would be handy. I just don't want to take on too much risk. So I figured I'd ask the collective for their experience and gauge the "norm".
thanks,
JeffD
4/24/15       #2: Clamp time for vac pressing…. ...
John Costin
Jeff --
Generally, you should use the same clamp time you would use in a clamped glue-up outside of the bag. For water-borne glues like Titebond, most of the water is going into the wood, so unless you've really hosed on the glue it will be absorbed at about the same rate as in an open-air glue-up. Same principle for two-part glues.
John Costin
Veneer Services Unlimited
vsu@gwi.net
207-985-7221
Custom Veneered Components for the Woodworking Industry
4/24/15       #3: Clamp time for vac pressing…. ...
JeffD
Hmmm, so no special considerations for the glue being sealed in an air tight bag? I guess I just figured the lack of air would slow the glue set? I know the glue that "escapes" the parts seems to take much longer to set anyway.
JeffD
4/25/15       #4: Clamp time for vac pressing…. ...
We have a 5X10 vacuum frame press and for flat materials (no stress) 30 minutes. Could probably go for less time since the glue seizes really quickly. Multi-layer curved parts, one hour then into a holding jig. Using Titebond original mostly except for veneer. Next day machining. Our pull down time is pretty quick, we tapped into the routers 40 hp Quincy. Also have two 4X8 bags but they are more of a PIA to use. But when there are lots of parts to press we can run them at the same time. We use the press a lot more than I ever thought we would.
4/25/15       #5: Clamp time for vac pressing…. ...
JeffD
Thanks Larry, so seems like the developing consensus is I'm wasting time leaving parts for several hours. I'm running an electric pump, but it still pulls down pretty quick, probably about 20 - 30 seconds or so for a 4 x 8 bag. One of these days I'm going to get a manifold and add a second bag. Figure that'll help move parts along as well.
thanks,
JeffD
5/21/15       #6: Clamp time for vac pressing…. ...
Max Neu
I also use a frame press like Larry mentioned, I just use the manufacturer recommended clamp times, and don't add extra time for vacum clamp.If using a PVA glue, I use titebond extend, it has the most rigid glue line of all PVA's, including the cold press glues, which are surprisingly soft.I also do not stack parts right after they come out of the press, I let them air out for a few hours before stacking.
