Adhesives
Board widths
8/11/15
Bob  Member
We are gluing up maple, cherry and basswood. Typically we use 5 pcs but some times there are as many as 9 pcs. I do not believe it has a bearing on the functionality of the board. Will it increase the chance of the cutting board to fail by having more glue joints? Or is it more likely to fail based how the board is cared for. As in soaking it in water or not oiling it so it will repel water.
8/11/15       #2: Board widths ...
Jeff Pitcher
Bob,
If anything, additional glue lines will make it stronger and more stable. Certainly soaking in water or not properly treating the board will cause much bigger problems.
9/11/15       #3: Board widths ...
JeffM
I would rethink using the basswood in a cutting board. Also, make sure you use at least Titebond II so the glue is water resistant.
9/11/15       #4: Board widths ...
Bob
The basswood is just for pizza peels. The cherry and maple are the cutting boards
