Adhesives
Wilsonart WA1730 Contact
3/4/15
Mark55 Member
Website: http://www.western-building.com
Being a long time Wilsonart distributor of their HPL & adhesives we have some of our fabricators experiencing some de-lamination issues recently. I just want to remind the industry this is a very high solids, very low VOC product (to be Calif. compliant). This product is not as forgiving as the good old WA800 high VOC product. 3.0 dry grams per sq/ft coverage is the minimum. Dry time is 3-5 minutes. Open time is no more that 30 minutes. 60-65 degree minimum when using. Make sure oil & water traps are functioning properly.
Use the recommended spray guns & pressures. This is a cadillac contact if used properly. If used correctly there should never be a failure.
5/6/15       #3: Wilsonart WA1730 Contact ...
Robert B. Member
Don't forget PRESSURE. The old days of using a block of wood or a three head flooring roller are over.
5/6/15       #4: Wilsonart WA1730 Contact ...
Mark55 Member
Absolutely correct Robert B. Applying UNIFORM downward pressure (30-40 psi minimum) is critical.
10/8/15       #5: Wilsonart WA1730 Contact ...
Richard Member
Where was Wilsonart 1731 adhesive manufactured?
2/9/18       #7: Wilsonart WA1730 Contact ...
Robert Member
WA 1730 is made in Temple TX across the parking lot from the laminate plant.
