Adhesives
EDGEBANDER GLUE
8/31/15
ERIC
I HAVE 3 EDGEBANDERS 2 HOLZHER CONTRIGA 1368, AND ONE BIESSE ROXYL 5.5. WE ARE USING DORUS 217 GLUE. I AM HAVING ISSUES WITH THE GLUE WORKING ON "HPL" I GET GREAT GLUE ON THE PART BUT THE LAM DOES NOT STICK TO THE GLUE. WHEN THE LAM PULLS OFF THERE IS NO GLUE ON THE LAMINATE. I WAS TOLD THAT I NEED A PRIMER ON THE LAM. IS THERE ANY GLUE OUT THERE THAT WOULD WORK WITH BOTH "HPL" AND "PVC" WITHOUT A PRIMER FOR THE "HPL"
THANKS!!!
8/31/15       #2: EDGEBANDER GLUE ...
Phil
the film on the back of the laminate is your issue. As far as i know you will always need to prime to treat this and don't take any shortcuts (brush not spray).
Push as hard as possible for non laminate banding. Color matches should be available and you dont have to worry about priming.
9/1/15       #3: EDGEBANDER GLUE ...
bruce
We pre heat our laminate edges with a heated table at the bander. Try it as it will stick then. Be very careful with what kind/type of primer you use.We went that direction once and had lam. edges falling off in the floor after a few days or weeks.Do a search here on laminate glue /primer compatabilty.
We tried most all brands glue manuf. and not one adhered to lam. good.
9/3/15       #4: EDGEBANDER GLUE ...
Rich  Member
We prime all HPL with Dorus EB primer and have no issues. We apply primer with spray gun before we cut sheets into strips.
9/6/15       #5: EDGEBANDER GLUE ...
Just like Rich, Dorus primer, spray full sheets. Have had no problems since we went this route many years ago. But best solution is to talk designers out of HPL edges. It also works well on solid wood edges.
10/31/15       #6: EDGEBANDER GLUE ...
alden Member
I dont mean to steal the thread but i did not find any place to post it else In anticipation of the griggio mobile edge bander hopefully arriving in the next week or so i have been looking into getting some glue supplies. Ostermann seem to do a good range and available in smaller quantities if required 2.5kilos or 25kg sacks. Any other suppliers that are better or cheaper? Whats the best colours to get? I was thinking of getting some white, transparent and a dark wood type colour or can you just get away with the transparent? is it a pain to change the colour over?
10/31/15       #7: EDGEBANDER GLUE ...
Alden, If you are getting a glue pot bander, it is a pain to change colors, unless you have a quick change pot and multiple pots to use.
The solution is to use a neutral or clear adhesive. The common adhesives have fillers in them, the clears don't, so they go further per pound. Buy the best adhesive you can. It is cheaper to pay more. We use both Dorus and Jowat, different banders. The specific adhesive should be based on the line speed of your bander. Cheaper banders typically run slow so need an adhesive with longer open times. Make sure to check the accuracy of your temperature controller. Use an IR meter directly on the application roll. If the machine you are getting doesn't have automatic filling of the pot, try to keep the level fairly constant. You will have less cleaning issues. Maintain the glue system!!! Keep a service record and clean it on time. If you allow the return channels to bake until they turn to charcoal you will have a real PIA session to clean them. Be sure to set the application thickness correctly. Don't let the panel drag on the application roller. Get some clear banding from you supplier so you can see the glue line. (They usually have small rolls of it they will give customers for free.) PVC & ABS banding comes primed. If you are going to put wood or HPL on you will need to prime it first. Some people just dilute yellow or white glue to use as primer, We use the Dorus product.
Good luck, a bander is probably the most productive piece of equipment in the shop.
5/6/18       #9: EDGEBANDER GLUE ...
O
All glue companies recommend priming HPL.
Find a good primer or if in a bind mix 50% paint grade lacquer thinner and 50% contact cement or 50% PVA 50% Water let dry well.
