Adhesives
structural gluelam adhesives? Who to talk to?
1/5/16
bob Member
I am in the engineering field but building a unique personal barn with some gluelam trusses. I need to spec an adhesive for this application. I have seen similar designs in the industry so they are using something. 3M only has 2 part epoxy products rating around 1000psi shear. I have also read a bit on MDI urethane products for this. I would prefer a single part product but that might be wishing. In any case, I will not have the ability to heat cure the glue. I want to obtain some samples and create a mockup test to test the bond.
2/10/16       #2: structural gluelam adhesives? Who t ...
I believe that epoxies cannot be used, because of high temperature(fire) failures. Resorcinol glue is typically used.
2/10/16       #3: structural gluelam adhesives? Who t ...
I 2nd the resorcinol. Sets hard and water proof. Follow the temperature recommendations. It is not gap filling, make tight joints.
