Adhesives
warped panels out of vac bag
1/20/16
Good Morning,
We are laying up 4x8 panels on PB with a VG laminate on one side and a white vertical grade laminate on the back. We are using TITEBOND COLDPRESS HPL 5.
We roll glue on one face using the special dimpled rollers,apply the laminate,flip the sheet, apply the back side adhesive and laminate and put 5-6 sheets at a time in the Vac press. When we open the hinged press lid, the sheets are flat, within minutes the top sheet will start to warp enough that we cant suck it down to spoilboard on CNc. I am sure it has to do with the moisture in the glue and the few minutes different one side is exposed vs the other. Is there a different glue we could be using to get a good hard glue line using our vac bag set up that works very well otherwise.
1/22/16       #2: warped panels out of vac bag ...
MacB  Member
have you ever used Unibond? It's a catalyst glue.
2/18/16       #3: warped panels out of vac bag ...
Gene Wengert-WoodDoc
I agree...this is a moisture issue and the water in the adhesive is likely the source.
There are pur adhesives without water.
There are dry film adhesives too but they require heat.
