Adhesives
High Heat
4/28/17
Scott Brady
I'm looking to attach a filler piece below an oven that has been prefinished, so i'm not wanting to use pins or mechanical fastners. Is there a glue that can handle the residual heat when a door is opened occasionally? Thank you Scott.
5/23/17       #3: High Heat ...
If it is below the oven it won't see much heat. I assume the oven is in and pocket screws are out of the question?
4/26/18       #4: High Heat ...
Cooler  Member
There are lots of choices: . https://www.google.com/search?q=heat+resistant+adhesive&oq=heat+resistant+adhe sive&aqs=chrome..69i57j0l5.8399j0j8&sourceid=chrome&ie=UTF-8
Furnace cement might work.
