Adhesives
ADHESIVE FOR BONDING LEAD SHEET TO WOOD
8/23/17
Matt
Hello,
I want to bond 1/64" thick lead sheet to a curved, uneven wood surface. I'm hammering/burnishing the sheet to the surface to make it tight and form-fitting. Any suggestions for an adhesive that can be used thin so it won't impede the tightness of the fit?
Thanks for your time,
Matt
8/24/17       #2: ADHESIVE FOR BONDING LEAD SHEET TO ...
Marty Member
Hey Matt,
We've used contact adhesive in the past.
Cheers Marty
8/25/17       #4: ADHESIVE FOR BONDING LEAD SHEET TO ...
Matt
Thanks, I'll give it a try. - Matt
10/9/17       #5: ADHESIVE FOR BONDING LEAD SHEET TO ...
Matt #2
Agreed with the above. I think I'd make sure the back of the lead was oxidized reasonably well, which should provide a better etching for the contact spray to work into, than fresh/shiney lead. Similar principle to painting aluminum, the paint adheres to the oxidation layer more than the aluminum itself.
