Adhesives
Moisture Content Variations Between Boards
3/22/18
Joshua Johnson Member
Hello,
Is there a good rule of thumb when it comes to selecting wood for glue up in a panel. We use hard wood boards (maple, walnut, jatoba, etc.) that can vary a bit in moisture content. We rarely have an issue but would like to narrow it down to zero.
Thanks.
3/22/18       #2: Moisture Content Variations Between ...
Jeff Pitcher
Hi Joshua,
If your wood is around 8-10% I think you'll be fine. You should definitely allow it to equalize with your relative MC before gluing. More important though is to be sure it's freshly machined as close to the time of gluing as possible. Hope this helps.
Jeff
3/22/18       #3: Moisture Content Variations Between ...
Never had an issue that I'm aware of in 20 years. Its common for us to receive a delivery of the typical hardwoods in the middle of a decent sized project. We don't think twice about mixing the "new" wood with the "old" wood that might have been sitting on our rack for a year.
In general most failures can be attributed to the glue itself, the glueing process, or the construction/design of the product.
Unless the lumber is soaking wet or you work outside there shouldn't be a huge amount of difference between your shop & the lumber distributor.
5/27/18       #4: Moisture Content Variations Between ...
Carverous Member
You will be fine if your wood is between 8-10%. I never had an issue with it. maybe you need to check the glue that you are using.
