Adhesives
Adhesive Choice Dilemma!!
10/11/18
Tom Norton Member
Have a project coming up to make 2 overhead garage doors. I made one in the past which faces northeast so it gets very little sun exposure. These 2 are directly facing west.
The first one I used Titebond 3. But on a few recent posts on Architectural Woodworking they had some failure with TB 3 when the temperature (surface?) Got too high.
I am looking for a suggested adhesive. The core of the door will be polystyrene inside a cedar frame with 1/4" exterior ply glued to it to make my substrate. Then a frame and panel on the exterior.
Thanks for your suggestions!!
10/11/18       #2: Adhesive Choice Dilemma!! ...
Jeff Pitcher
Tom,
I'd suggest looking at a reactive polyurethane glue. It will give you a better exterior bond than the T3 and is relatively easy to use.
10/11/18       #3: Adhesive Choice Dilemma!! ...
Tom Norton Member
Jeff,
I am not familiar with this. Is there a product/ brand??
10/11/18       #4: Adhesive Choice Dilemma!! ...
Jeff Pitcher
Hi Tom, ours is CP-0701
https://www.cpadhesives.com/woodworking-adhesives/cp-0701-polyurethane-adhesive-18
-ounce-bottle
It is available in a variety of sizes.
https://www.cpadhesives.com/woodworking-adhesives/cp-0701-polyurethane-adhesive-18-ounce-bottle
10/13/18       #5: Adhesive Choice Dilemma!! ...
Craig Caughlan Member
Website: wetimber.mx
Jeff-
Any idea how the CP-0701 compares to the Titebond Polyurethane?
10/14/18       #6: Adhesive Choice Dilemma!! ...
Jeff
I'm not too familiar with Franklin's PUR. I believe it is considerably thicker than the one we sell. Any of the PURs will give you a highly water resistant bond.
10/14/18       #7: Adhesive Choice Dilemma!! ...
Tom Norton Member
Jeff,
What is the coverage per gallon? Also does it react it used on polystyrene?
10/15/18       #8: Adhesive Choice Dilemma!! ...
Jeff Pitcher
You can figure on about 400 sq. ft of glue line per gallon.
10/15/18       #9: Adhesive Choice Dilemma!! ...
Tom Norton Member
How about the polystyrene reaction?
10/16/18       #10: Adhesive Choice Dilemma!! ...
Jeff Pitcher
Hi Tom,
It won't affect the polystyrene.
7/30/19       #11: Adhesive Choice Dilemma!! ...
KlausHe Member
Website: http://www.china-mingtai-al.com
3005 aluminum sheet is key products of Mingtai Aluminum, the quality is good, welcome to order!
View higher quality, full size image (750 X 420)
3005 aluminum sheet
