Subject: Re: How many Millwork Shops Use a "Locator Plate"
4/3/14
Roger Templeman  Member
Website: http://www.CadConDesign.com
1 Question Millwork Poll (Please Comment)
How many Millwork Shops Use a "Locator Plate" Fastened to the Floor for free standing Millwork Desks. (if No, How do you Secure the desks to the floor?)
View higher quality, full size image (3300 X 2550)
4/4/14       #2: How many Millwork Shops Use a " ...
scott
Use the plate like that often.
If it is something that is not stable a steel post is imbedded in the fixture and either grouted into a core hole or a bolt-down plate.
4/4/14       #3: How many Millwork Shops Use a " ...
joiner Member
I install them all the time from various makers. Without exception, they are made with removable panels on the inside face. Once the unit is in place, and shimmed level, holes are drilled down through the bottom plate, and into the concrete slab, tapcons are applied, and finally the loose panels are installed.
Trying to manage the really massive units up, over, and onto a pre-attached plate would be a real pain.
4/4/14       #4: How many Millwork Shops Use a " ...
Tom Devlin  Member
Website: http://www.southernmillwork.com
We do them the same as joiner. Since we got the CNC, we try to make the wall sections as large as possible, including corners & T's if necessary.
On occasion, for certain specific install requirements (ie, small), we will use the locator plate.
4/7/14       #5: How many Millwork Shops Use a " ...
scott
joiner - the way we do it we do not lift the fixture over anything. The posts are built in to the fixture. If it's core drill the posts extend 4", mark the floor where the posts are, drill the core & set fixture, use pour rock to fill the core hole. If there is a plate to bolt down, same thing, set the wall, mark the holes, drill for tap con or whatever & bolt down. The base trim covers the access to the bolts or core hole. Cleat blocks are pretty much the same. Set the fixture in place, mark it, move the fixture, & attach cleat to floor with whatever works for the floor type, concrete, wood, ect. Put the fixture or low wall back over the cleat & screw thru the side into the cleat. Been doing it this way more than 20 years sending to installers around the country who have no problem & it goes very quick.
2/23/22       #6: How many Millwork Shops Use a " ...
Joey Leandros
