Subject: Re: RUNNING PVC moulding on High speed moulder
5/13/14
Luke Member
Has anyone ever machined PVC on a high speed moulder? I have some questions regarding hold down, infeed - outfeed material handling , dust collection. Please let me know . This is a small custom job.
5/13/14       #2: RUNNING PVC moulding on High speed ...
I've run a bit of Azek. T&G mostly with a bit of profile work.
Dust: it goes every where. You will find it for years to come
Handling: see spaghetti. Needs good infeed and outfeed support.
Feeder: regular clean wheels with plenty of pressure.
It has the potential to chip. Mess around with feed speeds to get a good cut. It is heavy and floppy so it likes to fall off of carts. Be careful.
5/14/14       #3: RUNNING PVC moulding on High speed ...
Russ
Website: http://www.mirror-reflections.com
Luke
A company named NuCedar out of Massachusetts mills this type of product, the moulders operators name is Joe, he used to post here a few years back but have not seen him lately, they manufacture siding.
You would need carbide, you should be concerned about proper grounding of the machinery because of the static electricity PVC will create, especially if you have complex electronics on your moulders.
The company above has a lot of experience with this type of product I would contact them directly, Joe has been very helpful over the years and is an expert in this type of manufacturing.
Good luck
Russ @ MR
5/14/14       #4: RUNNING PVC moulding on High speed ...
Luke Member
Thanks to all who have responded. Much appreciated
Luke
11/19/14       #5: RUNNING PVC moulding on High speed ...
UFPLUKE Member
Has anyone ever used an Ionizer to combat static while machining PVC on a cnc machine or moulder?
