Subject: Re: stainless steel inlays gone wrong
12/10/14
John Bishop
We had a client request a stainless steel inlay in their dining room table. I was hesitant at first but a bit excited because it was something I had never done before. It could not have gone any worse. Just one of those jobs to where everything went wrong. I will not bother you with our issues with the stainless because we just pulled it out of the tables. The issue is we already finished them and we have to put a new inlay into them. I am going to route a wider slot and install a typical quartered wood inlay. But my concern is it will be set up flush to the lacquered surface. I have never done this before. I suppose it will be OK, not entirely sure. I do not believe it would be possible to strip or sand the cured catalyzed finish off the tables. I plan on routing in new wider slot and inlaying typical wood inlay and sand flush to the lacquered surface. Before we start the inlay work I am going to sand the heck out of the tops to try and remove as much lacquer as possible. So we do not end up over the thickness limit for the materials. Once the inlays are in and sanded clean we will apply a level sealer and finish after that as typical. What do you see that can go wrong here? I would prefer no more issues with this project its bleeding red already. But want to finish up properly and deliver a nice product.
12/18/14       #2: stainless steel inlays gone wrong ...
mark
Hmm, not sure: some of your previous problems might be design related, so just changing the material won't fix it?? You could post a picture. Have you considered pourable inlays: might be easier to make a good product while keeping additional costs low?
12/31/14       #3: stainless steel inlays gone wrong ...
Gary
Need more info.
Are you inlaying cross grain on a solid wood top? If so you are doomed.
