Subject: Re: Crosscut slab section of raw wood
1/27/15
pvick Member
1st - I am not a woodworker so am a complete novice when it comes to if this will work. We cut down a tree - one 24" trunk was hollow with the trunk forming a heart shape. Tree guys cut me several slabs of wood 4" thick- see attached. Want to preserve these for use in garden or other projects I have yet to think of. The wood is elm. Have been brushing on Pentacryl but if do multiple pieces it will be too expensive. Is it possible to preserve this w/o it splitting to pieces? If so, does it need to be dried before putting protective coating? Any ideas or advice would be greatly appreciated!
1/27/15       #3: Crosscut slab section of raw wood ...
Woodsy
This is a common question here - search the knowledge base on how to preserve log slices.
1/28/15       #4: Crosscut slab section of raw wood ...
Ok, since the topic has been raised, I thought I would share this personal experience. (Now back to the professional discussions).
I saved a slab several years ago. First I aged it in the garage for 2 years then finished it with a sealer then 20+ coats of spar varnish and multiple sandings in between. It has developed a small radial crack but it seems to add some character. The finished table has been in our garden for over 5 years now without further splitting.
Have a nice day all.
View higher quality, full size image (3473 X 1665)
1/28/15       #5: Crosscut slab section of raw wood ...
pvick Member
Thank you for both of your responses. I wasn't searching correctly so after putting in the right search words I gather lots of info. Dennis - what an incredible table!!! Thanks for sharing your experience!
