Subject: Re: source for honeycomb core
4/12/15
Butch Souter
biddinga job, need a source in Northeast for honeycomb corestock, 1 3/4" thick doors, up to 4-6'' x almost 10'
any ideas?
4/14/15       #2: source for honeycomb core ...
John Costin
You can buy it from Vacuum Pressing Systems. It comes in 24" x 48" sheets. If you haven't pressed it before, pay strict attention to the instructions!
John Costin
Veneer Services Unlimited
vsu@gwi.net
207-985-7221
Custom Veneered Components for the Woodworking Industry
Honeycomb core, Vacuum Pressing Systems
4/14/15       #3: source for honeycomb core ...
Kevin Jenness
The cardboard core stuff from Vacupress, unless things have changed, is rather pricy and comes in only 2'x4' panels of limited thicknesses. We have used a product called Plascore (Plaskore?) , a polyethylene honeycomb product that is available in larger sheets and various thicknesses for interior doors. We use the type with a scrim or veil surface to help with glue coverage. It works with pva and epoxy, and probably other adhesives as well. I can't remember the source offhand, but if you can't find it easily let me know and I will look.
4/16/15       #4: source for honeycomb core ...
Charles Wright  Member
Website: http://www.northcreekwoodworks.com
Plasicore is a good product. However, we were stocking a honeycomb cardboard for packaging and found that it is as good as anything for panel core. We simply made a wood frame, sanded it to match the honeycomb and pressed it with pre-veneered mdf core skins aprox 5/16" (remember to veneer both sides of the skins). You can get almost any thickness and it's available from local box companies. And it's cheap. Also do not hot press skins on a wood frame, it builds up pressure and I know of one situation where the 'box' exploded and took out the windows in a shop!
