Subject: Re: Live edge joinery question
7/15/15
wordsmith07 Member
Website: http://athenswoodshop.com
Rather than "bookmatch" two large slabs with a straight joint down middle, I want to do a midjoint that "follows grain" and place the slabs "side-by-side" with a wavy joint. Is there a way to get a tight joint other than a router with a curving template of mdf or other material? The slabs are 5/4 thick and spaulted maple.
7/15/15       #3: Live edge joinery question ...
find a shop with cnc router
7/16/15       #4: Live edge joinery question ...
doug mclaren  Member
lots of ways. if slabs are sliced the same you may have to reverse 1 , 180 degrees to get wavy edges to flow together. if you clean up one edge judiciously to sound wood joining them the way you would a laminate joint works. admittedly larger scale larger bushings or bearing cutters. but cutting 2nd edge close , then using 1st as edge for cutter to cut opposite. bowties look good to lock together.
11/12/15       #5: Live edge joinery question ...
Jay
an inlay bit set will produce a perfect fit template, -cut 1st pc any shape you like (bandsaw or jigsaw with a couple degs bevel, then clean with a large pattern bit. now use the inlay bit set to produce s matched template, rough the 2nd pc, then use template & finish cut with the large pattern bit (pattern bit= top bearing straight bit; inlay bit set = whiteside 9500 or similar
