Subject: Re: Flat Table Passage doors
9/9/15
Gavin
Hey guys,
Were a small traditional shop but have a great CNC with 4th axis capabilities.
We have been making passage doors and windows for years the traditional way with shapers and a mortiser.
I dont want to and I refuse to go to dowel construction.
I am wondering if anyone has been more creative than me in a way to produce the parts on a flat table cnc? I have an order for 14 doors that I want to do with a 2'' mortise and tenon. that will have a applied moulding on both sides.....there are about 4 different door sizes.
I am decent with alphacam but not an expert. I am looking to program all parts for one door at once on the table at one time....elevated by 1 1/2'' mdf to hold them down by vac. so my aggregate can get in there to do its work
Any suggestions?
Thanks in advance
9/10/15       #2: Flat Table Passage doors ...
gary
Try a computer forum. This one's for woodworking. Sorry to sound mean; just my 2 cents.
9/10/15       #3: Flat Table Passage doors ...
Alan F.
Gary,
Running a CNC is common practice and part of Architectural Woodworking these days. That said he will probably get more responses over in the CNC forum.
A-
Woodweb CNC forum
9/11/15       #4: Flat Table Passage doors ...
Will Williamson  Member
One of the techniques I have used is to make a 90 degree vacuum jig, that holds my door stiles vertical.
this eliminate the need for the aggregate to do the mortises. then I lined up all the rails and coped the ends and ran the sticking. One word of caution, when you vacuum down the parts, grab each part and try to pull it off by hand. If you can pull it off. you got a problem. That cnc will pull the part lose and kick back just like a shaper. You could be seriously hurt
9/17/15       #5: Flat Table Passage doors ...
Joe Calhoon
This is how a few router companies were doing M&T for windows at Ligna this year.
Tenon with a conventional router tenon head then round the tenons with the bit that cuts the mortises.
On pod and rail machines.
View higher quality, full size image (675 X 254)
View higher quality, full size image (435 X 274)
