Subject: Re: Small Press For Laminating
12/3/15
gary
Has anyone used the small Hydraulic presses that are sold for auto mechanic work for laminating small wood parts? I think they would work but the piston is center mounted and I would be concerned with distributing the pressure evenly. Any thoughts would be appreciated.
12/3/15       #2: Small Press For Laminating ...
Laminations
I am going to go out on a limb here and guess that you don't have a lot of woodworking experience or a lot of experience in laminating.
I have plenty of both, but your question is too vague for me to begin to respond to.
12/3/15       #3: Small Press For Laminating ...
gary
I had a feeling it may have been too vague; sorry for the confusion. The press I am referring to is sold for mostly pressing bearings and various metal type work. They usually consist of 4 posts with a hydraulic ram in the center. With 40 years of woodworking experience and the owner of a 4' X 8' cold press, I am always looking for better ways to laminate short runs and smaller parts.
12/3/15       #4: Small Press For Laminating ...
John S  Member
I have used exactly what you are talking about, but only to do small (12" X 12") samples. It works just fine, as long as you get it in and under pressure quickly. I used two 12" X 12" X 1/4" steel plates (one top, one bottom) to distribute the pressure evenly. I left the samples in over night, probably 14 hours, to make sure the glue was cured.
I wouldn't try it for anything much larger than 12" X 12", but it did work for me.
12/3/15       #5: Small Press For Laminating ...
B.H. Davis Member
Website: http://www.curvedmouldings.com
Why not just pick up a vacuum bag or small vacuum frame table.
A bearing press is going to concentrate all the pressure right in the center. You would need a very thick wood plate above and below the work for it to be effective. I don't think it would be worth it for larger than 6" x 6" pieces. Plus any bearing press over around 12" wide is going to be very costly. You could easily set up for vacuum presses for the same or less. If you have good mechanical abilities you can easily cobble together a vacuum system from inexpensive new or used parts.
12/6/15       #6: Small Press For Laminating ...
We've got a hydraulic frame press sold for mechanics. The pressure slowly leaks off. A mechanical press would be better. Press screws are available individually. Jorgensen about $25 each. Roton sells Acme rod & nuts but unless you are going to use a lot the Jorgensen ones are a better deal.
