Subject: Re: Full Round Handrail
Full Round Handrail
6/13/16
Kevin
I need to produce a some full round handrail, 1-3/4". I plan on doing it with the shaper and and some custom knives. Is the standard approach to leave a small flat and sand to blend? Any other suggestions? Thanks.
6/13/16       #2: Full Round Handrail ...
Leo G
I wouldn't. I would make it like a jointer and remove a small amount. If you do this your blank will have to be slightly rectangular.
6/14/16       #3: Full Round Handrail ...
Russ
Website: http://www-mr-moulding-knives.com
Kevin
Our standard would be to dissect the circle in quarters to reduce the depth of cut with a 1/16" overlap and 5/32" radiused blend area.
Some people elect to split the circle in two passes, but it has a deeper depth of cut and it will burn the closer the knife gets to ninety degree, your right, you will have to sand the blend areas doin it in two passes I guess it just depends on how much material you have to mill.
I hope the pics help you decide
All the best
Russ
FR_1P750.pdf
FR_1P750a.pdf
6/14/16       #4: Full Round Handrail ...
Leo G
I made a dowel jig with a bead cutter and a simple fence and feather board setup. It worked great. Two passes and done.
I'd do the same thing for this except I'd be using a shaper and a stock feeder. Once you have the setup good there would be little if any blending sanding.
