Subject: Re: Case clamping blind dadoes
1/6/17
John Schramm Member
Website: http://www.schrammswoodcraft.com
Does anyone have any experience with using a case clamp with blind dado construction. Our cabinet parts are machined on a nesting router, and presently we are stapling and screwing our cabinets together, but I wonder if it's possible to glue them and use a case clamp in order to speed up production?
1/6/17       #2: Case clamping blind dadoes ...
I have seen that done with white glue in the groove and hot glue in the corner to hold the joint while the white glue dries. I have also seen hot glue only in spots. I don't think it would speed you up with butt joints. Glue, clamp then staple?
We started using hot glue in certain situations for "clamping" only as described above. Then we tried some joints with grooves and clamping with hot glue only and I have a new found respect for hot glue. Its not just for grandma to glue flowers to hats. It can be amazingly strong. It seems hokey but it works.
