Subject: Re: Dyeing expoxy
Dyeing expoxy
1/24/17
Wood Dust
Does any one have experience dyeing epoxy ? Like what you see filling the large cracks on a live edge table? Is it the same resin like west system or is it a different material, and what creates the color?
Thanks in advance all
1/24/17       #2: Dyeing expoxy ...
You can use the dye that is sold for tinting epoxy or casting resin, dried coffee grounds for a variegated color look, or dry RIT dye. I've even seen guys use powder coat dry particles sold at Harbor Freight. If you want a thinner viscosity to flow into fine cracks, you can get clear casting resin and then you want to use the epoxy dye. Dry ingredients will make it more like paste.
1/24/17       #3: Dyeing expoxy ...
Kevin Member
I use this-
Jamestown Distributors Three Epoxy Pigment
1/25/17       #4: Dyeing expoxy ...
Dennis
Mixol colorants also work well for dying epoxy.
1/27/17       #5: Dyeing expoxy ...
Matt Krig
I've used black toner cartridge powder mixed into clear epoxy as a filler on slab tops many times. It sands and polishes great. Never tried any other colors.
1/29/17       #6: Dyeing expoxy ...
Gerry
I use Aniline dye (dry water-based) and it seems to work well. I read a chart somewhere that listed the effect on the strength of the epoxy of different pigments and Aniline dye had very little effect.
1/31/17       #7: Dyeing expoxy ...
Gene Wengert-WoodDoc
You can Mix or extend West epoxy with wood dust. West sells this dust. It is like wood powder. You can make your own too and Then have better color. I have used this technIque myself. The epoxy handles more like putty- -you have have time constraints but the strength is still high.
