Subject: Re: SCMI Sintex
SCMI Sintex
3/11/17
chris
I'm looking at adding a S4S machine to my setup, but would like to be able to run smaller mouldings, crown base etc. Does anyone have experience doing this with the Sintex? I'm having issues finding 35mm bore heads but can have them made. I'm limited on power as I have no 3 phase and run my 3phase equipment through a 75hp phase converter. 50hp is about the max I can go with my setup. A 5 head would be nice but haven't quite found one that would fit my power requirements. Thanks
3/13/17       #2: SCMI Sintex ...
David R Sochar
I had a Quattromat for several years, about 26 HP total, 4 head. We could do T&G and edge molding and face molding up to about 5/8" deep off the top head. Crown was fairly easy to run, but since it did not have molder type chipbreakers and holdowns, some sanding was required. We especially liked the jointer indeed table and fence. We had digital mechanical readouts and cranked to set up, but it was still fast and very productive.
3/14/17       #3: SCMI Sintex ...
chris
Thanks David. I've been looking at the Quatromatt as well. It seems hard to find 35mm bore heads for the sintex and the Quatromatt has a little wider width capability.
3/18/17       #4: SCMI Sintex ...
We have a 5 head Weinig with a total of 65hp. Since you don't start all motors at once and it is rare to max them all out at once I'd see about getting a 5 head molder instead of the S4S machine. I suspect you might find a 5 head with close to 50 total hp. It would be capable of running a lot of moldings, maybe not bar rail but how often?
Our machine has 1.5" spindles, commonly available heads.
There is always the option of using bushings, not ideal but can work. They would only be about 1/16" thick but any machine shop can make them for you. I'd also bet you can get heads made to order. I think 40mm heads are available stock, that would allow a bit thicker bushing, better.
I always wished I'd have bought a 6 head, two tops, but it was a $ issue at the time.
3/20/17       #5: SCMI Sintex ...
chris
Thanks for the input. I've been looking for a while at a 5 head unit, most are a little too heavy in HP, but I did talk with Weinig, they have a U217 model that is 55hp, so that might be a good route, however will most likely be new since I haven't seen one used as of yet.
