Subject: Re: APPLYING SOLD WOOD EDGE TO P-LAM TOPS
12/7/17
Matt  Member
We struggle with applying solid wood edges to laminate tops. Keeping it perfectly flush on top is the issue. The solid wood is 1.25 x 1.25 square applied to a 1.125 thick core with laminate on the top side.
We have tried, tennons, buscuits, glue line cutters, nothing seame to work well.
Any suggestions??????
12/7/17       #3: APPLYING SOLD WOOD EDGE TO P-LAM TO ...
D Brown
Fasten the wood to the edge of the core before you cover it with laminate , belt sand or trim flush then cover it that way the seam is covered as well.
12/7/17       #4: APPLYING SOLD WOOD EDGE TO P-LAM TO ...
Hoffman Lipping Planer.
Virutex also makes one.
Lipping Planer
12/7/17       #5: APPLYING SOLD WOOD EDGE TO P-LAM TO ...
Lamello also has a trimmer.
12/8/17       #6: APPLYING SOLD WOOD EDGE TO P-LAM TO ...
We have always used a spline. You can't put enough biscuits in to hold it evenly. The reality is biscuits are not really that accurate.
12/8/17       #7: APPLYING SOLD WOOD EDGE TO P-LAM TO ...
Chris
Website: http://csaw.com
Matt,
You'll want the Lamello Cantex edge lipping planer for this. I make all my Cantex demo blocks with white melamine edged with squirrely curly maple (with the grain running downhill). You can zero the cutter out perfectly, no tear-off because of the cone shaped cutter head, and you can go around corners with it. With the adjustable edge guide, I've had several shops plane the solid edge a couple of microns below the surface of the substrate so that when the finish is applied, it's coplanar with the melamine!
Depending on where you are, I could possibly arrange a demo?
Best,
Chris
http://www.csaw.com/lamello/specialty-machines/cantex-ergo
12/8/17       #8: APPLYING SOLD WOOD EDGE TO P-LAM TO ...
None of the solutions offered has solved the problem of the thickness of the finish sticking above the wood, that has been made flush with the laminate. If the laminate was masked, then the wood finished, you will have a ridge of finish above the laminate. The goal was to have the finished wood "flush."
The only solution to this, I've found, is to not use the splines or Lamellos and take the wood back off, finish it and very carefully glue it back on. If the wood edge is a full radius bull nose molding it must be made perfect, test fit, finished, then very carefully glued on using pads to protect the finished molding from clamp damage. We do it that way but it is a real PIA! Especially on curved work.
What have I missed, I've always wondered, because I have seen laminate table tops, with finished edges that are perfect, used in fast food joints. I assume the manufacturer has a much better solution that requires none of the labor that I put into it.
1/5/18       #9: APPLYING SOLD WOOD EDGE TO P-LAM TO ...
Russ
Website: http://www.mr-moulding-knives.com
Matt The link below is just an example of any size bullnose milled to any size to incorporate any amount of finish that will be applied to the moulding after the milling process. The groove in the panel would also require accuracy to make it work properly. Let me know if I can be of any further assistance, contact info on website. Good Luck Russ
Nosings
