Subject: Re: Digital Readout
Digital Readout
7/27/18
Geoff Wade
I am looking to setup two shapers with DRO units to speed setup times. I will be starting a job that requires multiple profile changes.
My question is, what brand have been tried and tested and any setup pitfalls that can be avoided.
7/27/18       #2: Digital Readout ...
Bill Member
We have several Accurate Technologies units in the shop. They have worked well for us.
We have them on a shaper spindle, works great. I am not sure how you would use it on a fence. You better get tooling made with the same diameter.
We do have a shaper set up for what you are describing using all insert carbide tooling. It is a CNC shaper where the fence, spindle and feeder are digitally set. It is pretty magical.
7/27/18       #3: Digital Readout ...
Bill Member
Sorry bad link
Pro Scale
7/27/18       #4: Digital Readout ...
David R Sochar  Member
We also have the Accurate Pro-scales on anything we can. They are a bit pricey but easily worth it in time gained. The read scale needs to be located as close to the real movement as possible to get the best results. We can easily tune tenons from slip fit to tight fit with just the DRO's.
7/27/18       #5: Digital Readout ...
Ken Member
Another vote for Accurate Technologies.
7/27/18       #6: Digital Readout ...
Geoff Wade
Thanks for the input on brand.
Dare I ask for anymore specific information on set up?
7/28/18       #7: Digital Readout ...
MarkB Member
The pro scale is great but when we have an application that doesnt have the proscale in the budget we recently tried the igaging dros available online mainly used for milling machines. They display in .0015 accuracy and have worked well.
7/29/18       #8: Digital Readout ...
Gary
Has anyone found a way to mount a DRO onto a powerfeed for the height off the table?
7/30/18       #9: Digital Readout ...
MarkB Member
We havent done that with a powerfeed because it really doesnt require .000" accuracy for us but I installed a scale on one of our feeders that doesnt have a laser engraved column for setting height. Just took aluminum rule and drilled and tapped a mounting hole for an angle bracket and then another for a pointer on the column. Its a little bit better than our old method of just marking the column (with a small kerf mark) for heights we commonly run.
With so many different angular configurations I never could see how a DRO would be beneficial unless you had one on every sliding and rotating axis. The scale on the main column for flat to the table height is all we ever needed.
