Subject: Re: Euro-joint ?
Euro-joint ?
12/14/18
Gary
I need to match some doors that have the typical European look; they have rounded the edges of the stile and rail where they meet forming a v-groove. Does anyone have any tips about dealing with glue squeeze out etc? I assume all parts are pre-sanded or no?
Thank you
12/16/18       #2: Euro-joint ? ...
Joe
Hi Gary, Part of the European door construction method is the finish. The first step in the process is the application of impregnator. The impregnator soaks into the wood providing rot protection, sealing and a good base for the primer coat to adhere to. It is less necessary to have glue go all the way to the edge of the joint due to the sealing from the finish system and by providing a better surface joint for the finish so it does not crack and allow water to penetrate the joint like the finish crack that occurs on a flush joint over time. Sirca and Milesi sell Euro waterbased finish systems in the US. Are the doors you need to match also rebated with Euro hardware?
http://www.sirca.it/en-US/coating
12/17/18       #3: Euro-joint ? ...
Gary
Hi Joe; I was hoping you would respond.
No Euro hardware but I still am wondering about glue squeeze out ? I was planning on using Titebond 2 extend. Clean up squeeze out with boiling water immmediately followed with fresh toilet paper to remove water residue. It is my usual system for any stain grade project. Will try to be careful with glue quantity .Your thoughts?
12/20/18       #4: Euro-joint ? ...
Joe Calhoon
I would think that would work. We usually hit any squeeze out with a wet sponge and a small pick like tool to get down in the crack. The very bottom gets filled with a compound at finish anyway.
This works with the water base finish but may not if using solvent based finish.
12/21/18       #5: Euro-joint ? ...
David R Sochar  Member
Most door manufacturers do not glue copes/sticking since the squeeze out is so hard to remove. Double if there is a v-joint at the ends/edges.
If you keep your glue in the joinery - dowels, mortise and tenon - then you should not have glue to clean out of the joint. Wet rag and some effort will take care of you in the learning curve.
1/3/19       #6: Euro-joint ? ...
Joe Knobbe
We use a wet tooth brush to clean up stray glue in those types of joints.
1/10/19       #7: Euro-joint ? ...
HarryProdigy Member
"We use a wet tooth brush to clean up stray glue in those types of joints."
Same here. It's more practical and efficient that way.
