Subject: Re: Exterior bench material
3/17/19
Dan
We have a job to build three solid wood park benches . We have to match existing they were made from white oak 23 years ago.
Does it make sense making them with wood that has a higher moisture content ?
3/17/19       #2: Exterior bench material ...
Only if you want more trouble with the joinery.
3/18/19       #3: Exterior bench material ...
RichardP
I know of a company that makes exterior wooden objects for a chain of garden centers. Much of this is white oak. They do not use kiln dried lumber. Wood projects should be made from lumber that has the same moisture content that will exist in use. Where I live exterior wood will most often reach 12%. Kiln dried wood at 7% will move a lot on it's way to 12%.
3/19/19       #4: Exterior bench material ...
BH Davis  Member
RichardP is correct. Go with local air dried lumber instead of kiln dried. You want white oak that has reached the ambient outdoor moisture level for your area.
3/19/19       #5: Exterior bench material ...
Keith Newton
Also, Keep in mind that you should only use heartwood. Sapwood of any species is going to decay quickly.
