Subject: Re: Metal Honeycomb door with Mirror 1 side
1/14/20
Michael Wood Member
We are making a door that is 1" thick x 15" wide x 96" high, We want to put a 3/16" thick mirror on 1 side. The core of the door will be 3/4" thick Metal Honey comb core with a 1/8" fiber face and veneer and 3" stave core stile and rail. Since we are using the honeycomb core would this door warp? Does anyone have any suggestions on how to attach a mirror on 1 side of a door with a frame.
1/18/20       #2: Metal Honeycomb door with Mirror 1 ...
BH Davis  Member
Can you incorporate some horizontal internal wood rails into the design? They would be placed at the mirror attachment point. The metal honeycomb would then go above and below the internal wood rails.
1/18/20       #3: Metal Honeycomb door with Mirror 1 ...
Fiber face. What exactly is that?
Why metal honeycomb(aluminum)? There is Nomex, balsacore, structural foam core(CoreCell) all of which are easier to deal with generally.
Who designed this layup? Bonding aluminum honeycomb can be a pain if you haven’t done it before.
The thing that will keep it flat will be the stiles and hinges(one side).
I’ve glued mirror to one side of a mdf smooth melamine door the same size. It has stayed surprisingly flat.(It’s been in my own house for 8 years. 5 euro hinges.
1/18/20       #4: Metal Honeycomb door with Mirror 1 ...
I’ve glued mirror directly to one side of a mdf smooth melamine door of the same size with silicone no frame. It has stayed surprisingly flat.(It’s been in my own house for 8 years. 5 euro hinges.
There isn’t much core. 9” wide.
