Subject: Re: Clamping/securing block on large core
1/24/20
Daniel Member
I am a door manufacturer and starting to do a fair amount of 1-3/4" flush doors that require solid blocking added to tops and bottoms of the core material.
The last job i drilled and drove 3" screws through into the core to "clamp it". It was a tedious task as well as filling the holes after.
I have a few clamp carriers but nothing that can clamp 80"-96" widths. Can anyone think of a better way of attaching these. Basically 36" x 5" x 1-3/4" blocks top and bottom of a substrate. I'm talking hundreds at a time not just a couple here and there that i could just use pipe clamps.
Thanks in advance.
I do not have an RF press/clamp.
1/24/20       #2: Clamping/securing block on large co ...
Could you rout a groove into the core and work a stub tenon maybe a 1/2" x 1/2" into the blocking. Then you can glue and tap into the groove. With the right fit it wouldn't need a clamp.
1/24/20       #3: Clamping/securing block on large co ...
Use a HiPur type glue gun to quickly adhere the edges of the blocks to the core. The skins will carry the load across from one substrate to the other.
There should be an adhesive solution to this problem.
1/25/20       #4: Clamping/securing block on large co ...
Collin Parker  Member
Website: heritagewoodwright.com
kinda what adam said. but long story short, quick dry glue with short time clamp/jig/whatever. It's same concept as volume cabinet door makers, most of them glue and 23g pin nail through rail/stile to hold joint till dry instead of clamping each for 24hr.
