Hammer Felder Saws
8/1/14
Rob
Would like to get some objective feedback from owners of Hammer's K3 and Felder K500 table saws. Other than promotional videos not a lot of reviews out there. Furniture maker here so saw will be lightly used and well cared for. Please no posts regarding used Martins or Altendorfs. Just looking for honest feedback from owners.
8/4/14       #2: Hammer Felder Saws ...
Dave E
We have a K500s. works nicely but a few details that could use improvement.
The lateral scoring blade adjuster screw has a very course cam so that moving the adjusting bolt 1 degree makes the scoring blade move 1/2 mm. would be better if it was a less sensitive adjustment. Changing blades and scoring blades takes about 5 minutes, then a bit for scoring adjustment.
Rolling table works very nice and it is easy to remove the outrigger table to get it out of the way if you need room.
The bearings are going on the scoring unit but not sure if it is from our use or they wear out after 3 years. Saw horsepower is good and accuracy is good. We use it everyday all day and it has performed well. It is not built as robust as bigger saws or other manufacturers but it is felders entry level saw. We can cut 9 feet and a bit on it and I have cut 10 foot solid surface slabs on it with a bit of fussing.
Another thing is if you slam the outrigger crosscut length stop back into the short position you will knock the outrigger fence left towards the blade without realizing it and then your cuts will be short. It tends to slip to the right if you are rough with it. Also when you bank the saw to 45 degrees you have to drop the scoring blade down to its lowest setting as it rises up dramatically as the unit banks over. If i was to replace it i would get the 700 level saw. That being said it has served us well.
