Warped walnut top
7/12/15
jeremy
I have a question on a 1 3/4" thick walnut top. We constructed many walnut countertops over the years and never have had any issues. We had one countertop in walnut we did years ago that we made and was installed by the cabinet installer. the top was about 3 ' wide and 12' long. The wood was kiln dried and was within 6-8% when we fabricated the top, it was finished top and bottom with tung oil. After about 6 months I got a call and the top was bowed slightly in the middle, I looked ant the top and the installer had fastened the top down solid on the edges and nothing in the middle and no slots in the holes for top to move. We had them fastest the top solid in the middle and slot holes on the outer edges. That was 4 years ago and all was well. I get a call the other day from the customer stating they wanted the top replaced or fixed, that they had an expert look at it and said it was made wrong. I am not sure what brought on the sudden change in the customer having issues. My question is how would you handle it? I have not seen the top yet and am going out to inspect. I feel like for some reason their must be some excessive moisture for some reason to make the top move in the recent months after 4 years. Not quite sure how to approach this issue. They never contacted us after we went back ad assumed it was fixed, due to install error. Am I missing something?
7/13/15       #2: Warped walnut top ...
Leo G  Member
Website: http://www.lrgwood.com
How did they suggest that the top was made incorrectly?
7/13/15       #3: Warped walnut top ...
Once they are committed to the idea that you made it wrong, you will likely need another expert to convince them otherwise. They may still feel they were wronged and not be happy with you over the problem. Might be that it would be best to take it back, split it in half, joint, and reglue. It will only be 1/4" or less narrower, and you will have a happy customer. Trying to convince them they are wrong, not a happy customer. What's it worth to you?
7/31/15       #4: Warped walnut top ...
jim
I would look at the plumbing and make sure there isn't an moisture build up for what ever reason. even a trash can? Have they maintained the top? what disclaimer did you have when selling a solid wood top.
To fix I assume it is bowed up? and I am not sure of the thickness of the top. you could possible screw some cleats on the bottom and pull it flat? Sand through a wide belt, and refinish.
My third question is how was it made? if it was made wrong I myself would be obligated to fix or replace. I would charge for plumbing and etc. all they get is the new top.
