2 Power Feeds on One Machine?
7/15/15
gary
I need to stick some large stiles (3.5" X 7" X 109") on my shaper and I'm thinking about using 2 power feeds to feed them and hold them down tight to the table. I know they may be running at slightly different speeds but I think this may not matter. Has anyone done this and what was the results.
Thank you
7/15/15       #2: 2 Power Feeds on One Machine? ...
Mack
I've done it. It's one of the most satisfying things I've done.
If you are seeing this message, your version of flash needs to be upgraded to view this video.
Click here to get the latest version of the Flash player.
7/15/15       #3: 2 Power Feeds on One Machine? ...
JeffD
An alternate idea may be to just add some indeed/outfeed support and run your feeder as normal. I bought a set of tables from Aigner for just this purpose….(though I also still have a set of shop built ones I use from time to time). They add maybe 42" or so to both ends of the shaper and make running heavy stiles a lot easier then having the feeder fight cantilevered stock.
good luck,
JeffD
7/16/15       #4: 2 Power Feeds on One Machine? ...
Joe Calhoon
We have a lot of practice running door and window parts at this thickness. In the early days of our euro door building we sometimes mounted 2 feeders on the shaper. It works but is a unhandy setup. We use this shaper for other operations and the second feeder gets in the way especially for curve work.
It depends on how much work you do like this. If a lot of production a 6 wheel feeder is the best solution. Otherwise Jeff has a good solution with support tables. We don't have any issues running thick stiles with a 4 wheel feeder.
Stile cuts usually are not removing a lot of material even at 3 1/2" and you should not have any problems if the work is supported. On deep cuts like euro frame profiles and the outside cuts on deep rebated edges we usually take a glazing bead out here before profiling and that helps a lot. You can also take 2 passes.
But to answer your question more wheels is better for large cuts. Our window machine has a 8 wheel feeder and holds thick parts very secure.
Attached is a video of doing outside profiling on a 92mm door. It is a tricky cut because the whole edge is removed with a split fence. We have had a lot of practice on large frames. Notice the extra support under the extension arm and the glass bead removed on the edges.
Outside profiling 92mm thick door
8/4/15       #5: 2 Power Feeds on One Machine? ...
Bruce H
Joe, I am impressed!
