Hess Mobil glue joint
10/20/15
RC
I have an edge press that gives inconsistent glue lines.
Some are good some gappy. Usually the tight side is facing the operator , and gappy on the back side of panel.
I have taken out heated platen bar and shimmed the rear edge to try to roll the heater bar and square up to panel edge.
I can get good results with something like oak(grainy wood) but maple or birch ends up looking pretty bad.
How have others tweaked this machine to get it to perform as it should?
10/29/15       #2: Hess Mobil glue joint ...
Are the gaps in the middle or the ends or random.
10/31/15       #3: Hess Mobil glue joint ...
RC
there seems to be no pattern, other than is almost always back edge. Do you have some theory ?? I did a test the other day with no heat and it seemed better, I am starting to think the heated platent is a fussy feature that needs more attention than I have been giving it, and that I may be shrinking the outer face of the hardwood edge,pulling it away from the substrate
10/31/15       #4: Hess Mobil glue joint ...
Seems like if it's always the back edge the platen may have a bit of a twist. Try having someone cycle the machine as normally used but w/o glue. watch how the joint closes. See if it will close properly when you put some thin shims where it is open. (deck of cards) You should be able to determine the location of the pressure fail by repeated shimming and clamping. If it is the platen & not just a weak clamp you are down to two choices. Tape some shims on it or take it to a machine shop & have it milled. Seems unlikely that it would be the heat bar.
11/1/15       #5: Hess Mobil glue joint ...
Out of curiosity, are you applying glue to the substrate or the edge? If you are gluing the edge, is it possible that the glue is curing in a thick glob in areas and not allowing the joint to close? Just a guess as I have no experience with an edge gluer.
11/2/15       #6: Hess Mobil glue joint ...
RC
hardwood strip is placed on platent and plywood edge is glued with a roller
