identifying wood panels used - MDF veneer
11/27/15
James Member
Hi
I am trying to identify the veneer panels used it these photos. The architect assures me they are black walnut, but the walnut sample you sent me is dark and chocolate brown not caramel brown. These panels will be a few years old however and in direct light so maybe it is the fading that gives them this look?
[img]http://www.zuberarchitecture.com/images/HP_4.jpg[/img]
http://www
.zuberarchitecture.com/images/HP_6.jpg
http://www.midcenturyhome.com/wp-conten
t/uploads/2012/05/Luke-Zuber-project.jpg
11/28/15       #3: identifying wood panels used - MDF ...
You can't go by color to identify a wood. Walnut changes drastically in direct sun. It becomes very yellow. If it was stained, very likely, the stain will also change. If it was grain filled that will also affect the current color because colorants were likely added to the filler.
If you have access to an area that can be scraped to natural, you will more able to ID. Freshly exposed walnut has a distinctive odder. The color, figure and grain pore patterns also help but butternut can be very close but lighter colored. I've seen all sorts of things sold as "walnut."
