Max width for frame
12/9/15
Jim
Hi All
I have to make a frame for stained glass (interior wall with a 5' x 5' opening). Top/bottom frame 12", sides 8", 5/4 cherry.
I was planning to rip/join 4" pcs. for width, but then I was thinking...my stock is about 14" wide, dead flat and straight and its been in my shop for over a year...could I use as is without rip/join??? It will be finished both sides/edges.
Thank you
12/11/15       #2: Max width for frame ...
Thomas
Yes, you can & i certainly would. Rip/joint/flip benefit is more myth than science. Stable seasoned wood utilized at correct moisture content is not destined to warp! Good luck.
