bending particle board
1/15/16
Steve Strain
Website: http://www.hallmfgco.com
We are repairing some church pews with a contoured back made of particle board. Close examination it appears to be a solid piece of 3/4" particle board with oak veneer on both sides. We have forms to match the shape but are unable to bend 3/4" PB without breaking it. We have seen several examples of this construction but unable to duplicate the process.
View higher quality, full size image (1296 X 968)
1/15/16       #2: bending particle board ...
Sit in your Pew
I can imagine several ways to bend particle board, but I can also think of several better material choices.
What broke on the originals? If it was the particle board that failed then it wouldn't make sense to duplicate that in the new work.
I would take time to explain to the customer that the job has to be done right, not just redone.
1/15/16       #3: bending particle board ...
As I recall hearing once, large manufacturers in the 30's and 40's made particle board in forms for the ecclesiastical trade. The parts had linear solid wood along the length for strength. Also done as plywood.
This was most likely done as a response to the cost of planing large solid curves in a wide planer/molder vs veneer.
1/15/16       #4: bending particle board ...
Why not just laminate thinner particle board or mdf? You didn't mention length, or quantity. For just a couple, I would think about laminating up a slab, and machining the curve on a CNC.
1/15/16       #5: bending particle board ...
Multiple layers of most anything thin vacuum pressed, then vacuum veneer it. Put MDF or P BD on your CNC and go to lunch, then veneer it.
1/15/16       #6: bending particle board ...
Steve Strain
Decided to go with what I know works 3 pieces 1/4' MDF. Character flaw I have of trying to figure out how it was done with out laminating.
5/27/18       #7: bending particle board ...
Ken
Why don't you try kerfing the mdf.
5/27/18       #9: bending particle board ...
Your solution sounds fine. We have a 5x10' vacuum table that I would use for something like this. I was curious about the air cylinder idea. Looked up the cost of 2" dia with a 3" stroke, $62. Given that you would need a lot of them because with shop air you will only get 300# of push out of each, seems too expensive. Toggle clamps? PIA to adjust. We have a Taylor clamp rack that goes to 12'. Very beefy clamps. 36"+ opening. I think that opening was a special order.
