Side lite with threshold, how to build?
3/5/16
Matt Calnen
I am building an paint grade entryway door with two side lites. They are not ganged together. I have built several doors before but never ones with side lites that have a metal threshold to match the door. What's the best way to install the side lite in the jamb? This was what I was thinking of doing; rabbit the jamb like the door but not use weather strip, and hold it in with stop from the inside. I was going to use a hardware store rubber bottem seal to make contact with the metal threshold. I would then gave the house painter caulk the outside seam and paint. This entry way only has a 2 foot overhang to protect it, and it faces lake michigan, so it has to be sealed up really well. I am making everything out of mahogany and plan to seal coat it with thinned down epoxy and prime it. Any thoughts or suggestions are welcomed,thanks, Matt.
3/8/16       #2: Side lite with threshold, how to bu ...
We do not use the standard metal sills too often, and we also advise against separate sidelights. Mostly because the framers that are forced to set them do a terrible job.
We remove the adjustable riser and all the little seals and stuff that are on the aluminum sill, and make a wood part that acts as a riser, with a tongue along the top. It is set into silicone in the sill, and the sidelight sash is plowed on the bottom to sit on top of the tongue, with about 3/16" gap between the sash and the shoulders of the sill filler. The sash is painted with good quality epoxy, and some silicone goes into the groove. This makes it all waterproof, but we also add a 7/16" x 1-1/2" +/- molded piece on the outside to provide an additional seal. It also is bedded in silicone.
We have used wood sills and made long ears so they are continuous on the outside and allow the exterior trim to sit upon them. The ears are bored, epoxied and cured, then an aluminum dowel is used to tie them together when they are set. If you can get the framers to slow down a bit.
