What is the best way to join wood for hollow posts?
3/30/16
Harold Pomeroy
I need to make many 6" x 6" x 8' hollow posts out of Cypress for an arbor. I need to use 5/4. What is the best way to join the corners? The wood will be left unfinished, so I expect some wood movement.
I'm considering lock edge miter cutters.
Thank you
Harold Pomeroy
3/30/16       #2: What is the best way to join wood f ...
pat gilbert
I would think the miters would open.
Maybe a rabbet joint or blind dado.
3/31/16       #3: What is the best way to join wood f ...
Edi Silva  Member
Website: silvawoodworking.com
Hello Harold
We make a significant amount of columns, from solid wood to pvc and we use lock miter cutter from Freeborn. No failures yet. Careful about leaving unsealed, make sure you get you *** out the way!!
Edi
3/31/16       #4: What is the best way to join wood f ...
Some movement seems like a big understatement to me. Why no finish? I sure hope it's old growth cypress or you'll likely get a call in a few years!
3/31/16       #5: What is the best way to join wood f ...
Harold Pomeroy
Thank you for the responses.
I plan on using a rabbet-dado joint, and a lot of stainless steel fasteners.
I have already explained what will happen to unfinished wood left out in the elements, and they also have other unfinished wood on site.
Harold
4/1/16       #6: What is the best way to join wood f ...
chris
Website: http://www.hofmannjoinery.com
Good point in the earlier post by Rich C. I had a huge problem with "modern" cypress that I used for German siding and trim on my house. I thought it'd be a perfect exterior material, only to learn later that new cypress is basically junk - harvested too early, no heart wood.... Even though I hated working with it, maybe Spanish cedar would be a better choice? In terms of joining the miters, I use the Tenso connectors by Lamello for clamping/gluing up all kinds of miters. They're awesome, they pull surprisingly tight.
Tenso Connectors
4/1/16       #7: What is the best way to join wood f ...
I agree with your rabbet and dado joint. Made properly on the shaper, it is fast and accurate, easy to assemble, and achieves the goal of increased glue surface by nearly doubling it. The problem with these usually comes with the cross grain wrapping of base or crown/cap mold that will open a fret the column shaft swells a bit.
4/2/16       #8: What is the best way to join wood f ...
Mark
I would use one of these two assy's - I think the top one is easier to put together though
Post_assy_2.pdf
