Gluing Port Orford Cedar
4/8/16
B.H. Davis Member
I'm doing a quote with Port Orford Cedar. A little online research shows it to be a very workable material.
What I haven't found though is what type of glue to use. I've found references to it working well with glue but not to specific types.
This is a stain grade project so I'm hesitant to just plan on West System epoxy due to the glue lines.
Does anyone have experience with gluing this wood species?
Thanks,
4/8/16       #2: Gluing Port Orford Cedar ...
D Brown
I have had good results with titebond
original , should be no problem except for the smell , good luck .
4/8/16       #3: Gluing Port Orford Cedar ...
Peter Member
You don't mention if it is interior, or exterior application? If exterior, I have had better luck gluing with a powdered resin glue like CP Adhesives CP- 0503 product for durability over years of exposure than any of the epoxies I have tried.
That is pretty much my exclusive exterior product based on in field testing over about 12 years of exposure.
4/8/16       #4: Gluing Port Orford Cedar ...
B.H. Davis Member
Thanks guys.
These are curved frame components for some high end windows. As such it must be considered an exterior project.
4/8/16       #5: Gluing Port Orford Cedar ...
Peter Member
Even better. I also do all my bent laminations with this, as it is a rigid set glue, with no creeping.
4/14/16       #6: Gluing Port Orford Cedar ...
Paul S
Uni bond would work well.....it can be mixed with a light or dark catalyst depending on desired stain color.
