Dust Ducting
2/3/17
Gary Gilbert
I am wondering; if there is a 6" outlet from my dust collector should I keep the ducting that size as far as possible ? Or is there an advantage to reduce the diameter?
2/3/17       #2: Dust Ducting ...
As far as possible? Do you mean all the way to the furthest machine? Depends. Duct design is based on velocity of air and quantity of material to be moved. If your thickness planer is the furthest machine, yes you need a large diameter trunk line. If the furthest machine is a spindle sander, no.
