Bending Materials -- 1 --
3/23
I am interested to know what some other shops are using to skin your radius walls. We do a lot of reception desks & nurse stations and are currently using 1/4" MDF, 3/8" MDF and bending ply. Shop doesn't want to use kerf core. These are laminate walls. Is there another sheet material out there that is good for radius applications?
3/23 #2: Bending Materials ...
we use kerf core on a form in a vacuum bag.
"if its worth doing............"
3/23 #3: Bending Materials ...
Kerfcore
View larger image
3/24 #4: Bending Materials ...
For those of you who are using kerf core how are you attaching it to the frame? Glue/vacuum or fasteners?
3/24 #6: Bending Materials ...
We use bendable plywood (Lauan). We use 3/8" which is actually 5/16" thick, We double it up, gluing the two layers together. To smooth it out, we will use Bondo and then sand it smooth. If the Bondo tends to thicken too soon, we will add some lacquer thinner to make it more liquid and give us more time to work with it.
Was your wall cut with a CNC router?
3/24 #7: Bending Materials ...
I make a frame, dado/rabbet the kerfcore and then glue and staple. Fill the staple holes and then either use contact cement or PVA depending on the material I adhere to it.
The frame is designed on a CAD and sent to a CNC shop to get milled. Makes all the curves the same.
View larger image
3/24 #8: Bending Materials ...
Kerfcore and Flexcore, you'll never look back. I use glue and staples and fill the fastener depressions depending on the veneering product. You'll save money on labor, probably materials and enhance your quality as well. Use the Kerfcore on the convex side and Flexcore on the concave side. Flexcore can be laminated first and then installed so I leave the portion of the wall below the countertop off, deliver the wall, tapcon it to the floor, let the electrician and data guys have their turn and come back and install the Flexcore on the wall. Sometimes we install the electrical boxes in the shop and run the flex for the electrician and leave an access panel for the final connection. I also pre drill my studs for conduit or cable.
3/24 #9: Bending Materials ...
Another vote for kerfcore!
Really easy to work with. We make 3/4" ribs, and then staple 1/4" ribs that are 3/8" wider to those. dado the back of the kerfcore to receive the ribs. Then glue and clamp it together (we are doing paint grade work)
1 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
