house doors
6/6/17
bob d. Member
how would you make 50 to 100 interior doors a month, i would like to mortise and tenon , ?? or would you dowel ??
6/6/17       #2: house doors ...
Steelie Mark
If you have a tennoner that has cope heads, a fairly automatic mortiser like a Maka or Bauerly , then you could probably make your goal doing m&t.
And if you had a good automatic boring machine with at least 2 heads, or maybe something like an Ayens, you can again make your goal.
This is all assuming you have at least one shaper or moulder of production quality to produce the stiles and rails, and in the case of dowels, possibly a second shaper with a sliding table to do the cope work; a good clamp rack like a Taylor and enough skilled personell to do it.
Then 50 to 100 is doable.....
6/6/17       #3: house doors ...
bob d. Member
mark , i've been doin this for a while , have 6hd moulder 3' planer , gangrip saw , 5 shapers , and wide belt , slider saw , plus 2 table saw , have done custom doors just a few at a time , but now i've got a guy wanting me to do doors day in and day out , trying to do some kind of volume i know i don't have all the right tools to do it .
6/7/17       #4: house doors ...
Steelie Mark
Bob, it sounds like you're well tooled ; how have you made doors in the past?
As my experience is with M&T, I'd suggest a tenoner with cope heads, an auto mortiser & clamp rack for the volume you're looking at.
Doweling is certainly a viable option, it just introduces more parts per door- maybe a dowel glue and insert machine?
Getting tooled for doweling will be cheaper as you really only need a good boring machine in addition to what you have.
If you have the room, you should consider making machines, space and crew dedicated to door making only- once set up, leave it set up.
Consider- a run of 50 six panel doors is 700 machined parts, 700 copes, 400 tenons/dowel placements(if you don't tenon/dowel the interior stiles)
Lotta good work, hope it works out for you.
6/7/17       #5: house doors ...
Steelie Mark
OR,( forgot to say) a dedicated CNC machine- pennies to run once set up.
6/28/17       #6: house doors ...
Geoff
Bob,
I would dowel with number of doors you want to make. Horizontal boring machine and some type of flip stop fence (Tiger Stop).
CNC?
If I may ask, what is your door clamping system? It can be a bottle neck for us when doing larger door orders.
6/28/17       #7: house doors ...
bob d. Member
i havn't got to address to issue yet , your thoughts?
6/29/17       #8: house doors ...
Geoff
I am not qualified to answer that question,
We are no where near that amount of production.
Currently we use bar clamps. I have looked at JLT pneumatic door clamp but I still see a problem with the time the door is in the clamp while the the glue is drying. At one point I thought a RF glue system would work but that doesn't seem possible. My latest thought is to get two pneumatic clamps but we don't have the space.
So, I am stuck with the slow, heavy bar clamp system.
