wood block flooring
7/14/17
macks Member
looking for information/wisdom on laying a wood block floor in my shop. I've got 4000 sq feet of floor to do, and access to endless perfectly sized and squared 4X8 douglas fir mill ends. My thought is to screed level then compact gravel then lay in the 3" tall blocks end grain vertically . Does it need to be more complicated than this?
7/14/17       #2: wood block flooring ...
I worked in the Caterpillar East Peoria, IL factory for a year in 1972. Wood block floor as far as you could see, acres of it. All that was dry set on concrete, then covered with a tar-like liquid to seal it from coolant leakage for all the manufacturing machinery. My last career at Cat was in the Industrial Design Department. They redid the office and I talked them into a block floor in part of it. It looked great, but boy did the cracks open up in winter! I would not lay it on gravel. You'll get moisture coming up around the perimeter and making a mess of the block. Also tough to keep it from moving around with seasonal shrinkage. Dropping a few screws will result in instant disappearance in the cracks. Sweeping up sawdust will be less of a task, it's going to take years for all the cracks to fill up with it!
