best resaw blades -- 1 --
1/22
Wondering what is the better blade for a 20" resaw? Do you think a Lenox bi-metal will last twice as long as a carbide tiped? The price of the bi-metal is a little less than half the price of a carbide. I resaw mostly hardwoods and have to run a lot of bf. in a couple of weeks.
1/22 #3: best resaw blades ...
I have used both the Lenox Classic Pro (bi-metal) and the Woodmaster C (carbide). I much prefer the carbide for life and smoothness of cut.
1/24 #4: best resaw blades ...
20" is a fairly small wheel for resaw band saws. This makes for tighter flexing and greater stress on the blade band.
With a 20" saw I'd be inclined to go with the bi-metal blade. If I had the carbide blade I'd want to be able to resharpen it. The extra stress on the band could cause premature failure of the blade in terms of multiple sharpenings.
Lenox though is a great choice for the brand.
1/24 #5: best resaw blades ...
You should have no trouble in terms of life with Lennox carbide blades on your 20" saw. I use a Woodmaster CT on my 17" saw w/o issue to cut hardwood veneer up to 10" wide. As Kevin said, the smoothness of cut is much better than bi-metal, at least the ones I've used, and the time between sharpening must be at least 5X.
The issue I'm having is finding someone that can sharpen Lennox carbide blades. As far as I know Lennox does not offer a sharpening service. So if anyone knows a source I'd appreciate hearing it. Thanks.
John
1/24 #6: best resaw blades ...
John, I have the carbide on order. They did say that it's a good idea to take the tension off the blade when not in use. I thought this was interesting. I have looked some for someone to sharpen their blades, so far no luck, will let you know if I find anyone.
1/24 #7: best resaw blades ...
I do take the tension off the blade when I'm not using it, but I have a friend using the same blade on an identical saw who leaves his under constant tension. He's had that blade on his saw for well over a year now w/o issue. We are both running around 25K psi tension.
If I find someone who can sharpen these blades I'll return the favor. Thanks. If I strike out all around I'll try sharpening it myself; I'll have nothing to lose at that point. I've sharpened bimetal blades with good success, although the tolerances for the CT are much tighter.
John
1/25 #8: best resaw blades ...
We run the CT Lenox blade as well, I have also struck out finding anyone who will sharpen it. But they do last forever
1/25 #9: best resaw blades ...
What are you all using for blade width?
I've found that on my old 18" Lugan Resaw Master that 1" and 1 1/4" wide blades eventually failed due to stress cracking. The tension on the saw was always released when done. The saw got hours on end of use though and we'd get months of use out of the bi-metal blades.
1/25 #10: best resaw blades ...
I use a 1" x 1.3 tpi on my 17" saw. It's rated up to a 1-3/8" blade, and I think it actually could put 25 K psi on one, but I see no reason to go wider. It cuts as fast as I can push wood through it and cuts beautifully straight and pretty smooth, so I see no benefit to go wider. I've cut many hundreds of sq. ft of veneer with this blade so far and it's still cutting well.
For those w/o a power feeder you might be interested in this device I built, based on John Lanciani's design, to keep the workpiece tight to the fence - and your hands away from the blade. It makes sawing veneer a simple and safe task.
John
View higher quality, full size image (3648 X 2736)
1/25 #11: best resaw blades ...
John, How are you checking the tension of your blade? I'm also using 1" blades and my saw will take up to 1 1/4" but it seems to like the 1" the best. I've never had a problem with cutting straight. Thanks for the pix of your setup. I have something similar but not as slick as yours.
1/25 #12: best resaw blades ...
I use a simple set up like shown in the photo, just a set of digital verniers and two small clamps. At zero tension you set the gage length (distance between the vernier jaws) at some value, say 5", and zero the display. Then you add spring tension and observe the change to the reading on the vernier display. That value is related to the tension in the blade by knowing that
Young's Modulus = Stress / Strain, or
Stress = YM x Strain
The Young's Modulus of steel is about 30 x 10^6 psi. The strain is the value you observe on the vernier display/gage length. So let's say you apply what you think is the normal tension on the blade and the vernier shows 0.004" on the display (Doesn't matter if the value is + or -.) If the gage length was 5" then the calculated strain is 0.004"/5" = 0.0008. Multiple that by the Young's Modulus of 30 x 10^6 psi and the stress in the blade is 24K psi.
Hope that helps. Just make sure to clamp the verniers securely to the blade. It helps to repeat the test two or three times to make sure the measured values are consistent. Once you are confident the test works well you can easily create a graph or chart of spring tension (using the indicator on your saw) vs. blade tension, for each of your blades.
John
1/26 #13: best resaw blades ...
Let's try the picture again.
John
View higher quality, full size image (1200 X 1600)
1/26 #14: best resaw blades ...
I got a note from Connecticut Tool and Saw saying they can sharpen Lennox carbide blades, for approx. $35 - $50 depending upon length. Also, they sell new Lennox blades as well. I will definitely give them a try when the CT blade on my saw starts to dull.
John
http://ctsaw.com/
2/2 #15: best resaw blades ...
I tried the ReSaw King carbide blades on my 20" Delta and while they do last longer, they didn't last long enough IMO to justify the price. I then tried a Lenox bi-metal blade and have been using them for the last several years. They don't last quite as long, but I can buy three of them for what the RSK cost and seem to get a lot more mileage. I can also grind the tips in a pinch if I don't have a spare bade around....can't do that with the carbide. Everyones got a favorite though so you'll just have to try some out to see what yours is.
good luck,
JeffD
1 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
